Re: 1976 Motobecane 50 stalls when it gets warm
Rebel Moby /
You can not see the splice that goes to the external coil primary terminal but it is there...
Original condenser as seen in the top picture is wired directly to the points - blue wire with back tracer - you need to disconnect it from the points. If you do not remove the original condenser, cut the pigtail short and make sure the wire will not foul in anything moving.
> Phil Burtner Wrote:
> Well, that coil mounted option looks pretty easy. Is there an existing
> electrical connection point there? It looks like you just disconnected
> an existing connector and reconnected the new condenser to the coil side
> of the the existing connector. I assume the disconnected side goes down
> to the bad condenser?
  1976 Motobecane 50 stalls when it gets warmTopic by: Phil Burtner Phil Burtner 10/23/19 08:23PM
  Re: 1976 Motobecane 50 stalls when it gets warmRe: Phil Burtner Phil Burtner 10/23/19 08:25PM
  Re: 1976 Motobecane 50 stalls when it gets warmRe: Aaron Blair Aaron Blair 10/23/19 09:19PM
  Re: 1976 Motobecane 50 stalls when it gets warmRe: Stephen Keller Stephen Keller 10/24/19 03:39AM
  Re: 1976 Motobecane 50 stalls when it gets warmRe: Rick Bergsma Rick Bergsma 10/24/19 06:23AM
  Re: 1976 Motobecane 50 stalls when it gets warmRe: Phil Burtner Phil Burtner 10/24/19 07:17AM
  Re: 1976 Motobecane 50 stalls when it gets warmRe: Rebel Moby Rebel Moby 10/24/19 10:15AM
  Re: 1976 Motobecane 50 stalls when it gets warmRe: Phil Burtner Phil Burtner 10/28/19 11:55AM
  Re: 1976 Motobecane 50 stalls when it gets warmRe: Rebel Moby Rebel Moby 10/28/19 03:42PM
  Re: 1976 Motobecane 50 stalls when it gets warmRe: Phil Burtner Phil Burtner 10/29/19 08:16AM
  Re: 1976 Motobecane 50 stalls when it gets warmRe: Rebel Moby Rebel Moby 10/29/19 10:08AM
  Re: 1976 Motobecane 50 stalls when it gets warmRe: Phil Burtner Phil Burtner 10/29/19 02:01PM
  Re: 1976 Motobecane 50 stalls when it gets warmRe: Rebel Moby Rebel Moby 10/29/19 04:52PM
  Re: 1976 Motobecane 50 stalls when it gets warmRe: Phil Burtner Phil Burtner 10/29/19 07:26PM
  Re: 1976 Motobecane 50 stalls when it gets warmRe: Rebel Moby Rebel Moby 10/30/19 09:22AM
  Re: 1976 Motobecane 50 stalls when it gets warmRe: P D P D 10/30/19 10:51AM
  Re: 1976 Motobecane 50 stalls when it gets warmRe: Stephen Keller Stephen Keller 10/29/19 03:21PM
  Re: 1976 Motobecane 50 stalls when it gets warmRe: * * * * 10/31/19 02:12AM
  Re: 1976 Motobecane 50 stalls when it gets warmRe: Silverfox Sullivan Silverfox Sullivan 10/31/19 05:38PM
