Stripped Puch Intake stud
Angry Hipster /
So it looks like I've stripped my intake stud on my stock aluseries cylinder. To make matters worse, it looks like after doing some research that the stud is cast in the cylinder and non removable.
Is the only option to cut off the stud and drill and tap? Thanks
Re: Stripped Puch Intake stud
Yep. Center punch the stud after you cut it flush, then make a pilot hole. Then drill out for an m6 helicoil. Try not to gouge up the mating surface of the intake port
Angry Hipster /
Thanks for the advice. I just ordered a knock off dremel tool, a spring loaded punch, and an m6 helicoil kit, and a new gasket kit.
The cylinder probably isn't worth all that but I'll get some cool tools to keep.
> to keep.
Not to mention , a leak free runner . ;)
