Hi everyone,
You know the story, it was working great, then a friend borrows it and returns it not working.
I’ve replaced all of the following parts below and it doesn’t turn over. It has good compression and spark.
Cleaned tank
New gas
Pepcock replaced
Gas line
Gas filter
Rebuilt carb/cleaned carb
Carb starter spray technique tried
Tried to kick it over multiple times down a long steep hill.
1st Picture - This part is rusted and doesn’t work how it use to. It’s some interesting spring that disengages a rod from inside the engine, pretty sure it’s the choke and lets more air into engine when starting. I’m assuming I should replace it but where do I find the part? Thanks for any help
Second and Third picture - Know where I can get this part? Is it the solenoid or coil??? brand Boch
3) how hard it is to un-seize or redo a post one in a moped?
Thanks and any help or advice!
Mr Sachs
