could No trans oil, I had a hobbit with a bad trans side bearing once that made the noise you’re describing. Rebuilds are easy and fun on E50s if it’s the crank stock cranks are cheap and abundant. Given that It runs already sounds like a reasonable deal for 200!
Re: Puch e50 bearing noises.
Subject | Written By | Posted |
Puch e50 bearing noises.Topic by: David McHugh | David McHugh | 10/20/19 08:01PM |
Re: Puch e50 bearing noises.Re: Jeff Parr | Jeff Parr | 10/20/19 10:46PM |
Re: Puch e50 bearing noises.Re: Overpriced Parts | Overpriced Parts | 10/20/19 11:29PM |
Re: Puch e50 bearing noises.Re: Born to be WillD | Born to be WillD | 10/21/19 04:24PM |
Re: Puch e50 bearing noises.Re: Bas Autowas | Bas Autowas | 10/24/19 10:58AM |
Re: Puch e50 bearing noises.Re: David McHugh | David McHugh | 10/23/19 12:11PM |
Re: Puch e50 bearing noises.Re: Dan (high idle) Conway | Dan (high idle) Conway | 10/24/19 10:53AM |
Re: Puch e50 bearing noises.Re: David McHugh | David McHugh | 10/24/19 01:45PM |
Re: Puch e50 bearing noises.Re: David McHugh | David McHugh | 12/03/19 06:24PM |
