Anyone been through this already and have a suggestion?
Need replacement bushings for a General 5-Star stock swingarm.
Thanks!
Thanks!
if you can't find anything you can always use the right size bolt with a piece of rubber hosing over it just make sure it is good thick hosing it will last probably three seasons but I would suggest you find 1 from a hardware store a lot of times they'll have Stoppers and you can drill one
yea i used some oiled brass bushings from mcmaster. but on a balboa i had the same prublem and used some nylon bushings, i think that was a little easier, both worked fine. you just need to measure and see what you can find that's close or exactly correct.
Do you have a picture of the old ones?
So here's a question can you put a sax swing arm on a TOMOS it looks wider can I space it I just want to run 17 grimeacas on it...
