Oh now I see when you're reassembled the clutch the inner COG was put in backwards the old wear put a little lip on it so that it only goes one way in other words it won't compress all the way if it's backwards the little lip caused it to always rub on the inside of the donut and they're supposed to be too thin washers on the outer sometimes I'll skip a plate and get a super thick washer for an anchor plate to take up that space where those two washers go
