Re: Peugeot Vogue / 103 Variator question
cheetahchrome . /
What is happening to your carb is you still may have the stock intake on the motor. The stock intake is cast off set so that it works perfect for the gurtner. The carb is hitting your swing arm when it variates down. If you run a Del 15mm you need to also switch to an aftermarket center cast intake that keeps the 15mm in the center so It wont hit the swing arm and get wrestled off.
The same thing happens to gurtner carbs if you try to run them on an aftermarket center cast intake, the carb rubs and gets kicked off.
This is a unshakeable rule people. I have spoken.
In the picture the stock Peugeot intake is on the right and you can see the offset. The one on the left is aftermarket Malossi and sits dead center.
  Peugeot Vogue / 103 Variator questionTopic by: Sean Colvin Sean Colvin 10/14/19 06:28PM
  Re: Peugeot Vogue / 103 Variator questionRe: Rebel Moby Rebel Moby 10/14/19 07:29PM
  Re: Peugeot Vogue / 103 Variator questionRe: Sean Colvin Sean Colvin 10/14/19 08:15PM
  Re: Peugeot Vogue / 103 Variator questionRe: Born to be WillD Born to be WillD 10/14/19 09:56PM
  Re: Peugeot Vogue / 103 Variator questionRe: Sean Colvin Sean Colvin 10/15/19 07:29AM
  Re: Peugeot Vogue / 103 Variator questionRe: LL danktip LL danktip 10/14/19 10:09PM
  Re: Peugeot Vogue / 103 Variator questionRe: Stephen Simmons Stephen Simmons 10/15/19 05:52AM
  Re: Peugeot Vogue / 103 Variator questionRe: pat splat pat splat 10/14/19 10:29PM
  Re: Peugeot Vogue / 103 Variator questionRe: cheetahchrome . cheetahchrome . 10/15/19 12:09AM
  Re: Peugeot Vogue / 103 Variator questionRe: Stephen Simmons Stephen Simmons 10/15/19 05:55AM
  Re: Peugeot Vogue / 103 Variator questionRe: jumpsuit steve jumpsuit steve 10/18/19 08:35AM
  Re: Peugeot Vogue / 103 Variator questionRe: Rebel Moby Rebel Moby 10/18/19 09:41AM
  Re: Peugeot Vogue / 103 Variator questionRe: Sean Colvin Sean Colvin 10/18/19 09:54AM
  Re: Peugeot Vogue / 103 Variator questionRe: Rebel Moby Rebel Moby 10/18/19 09:59AM
  Re: Peugeot Vogue / 103 Variator questionRe: cheetahchrome . cheetahchrome . 10/18/19 10:32AM
  Re: Peugeot Vogue / 103 Variator questionRe: Sean Colvin Sean Colvin 10/18/19 01:14PM
  Re: Peugeot Vogue / 103 Variator questionRe: cheetahchrome . cheetahchrome . 10/18/19 07:37PM
  Re: Peugeot Vogue / 103 Variator questionRe: Sean Colvin Sean Colvin 10/18/19 07:28PM
  Re: Peugeot Vogue / 103 Variator questionRe: cheetahchrome . cheetahchrome . 10/18/19 10:14PM
  Re: Peugeot Vogue / 103 Variator questionRe: Sean Colvin Sean Colvin 10/18/19 11:12PM
