Re: Peugeot Vogue / 103 Variator question
Sean Colvin /
It’s running great now. Tightened up the motor mounts and messed around with some jets. The rattling is actually a broken piece of the baffle inside the exhaust shaking around like crazy. Either I’ll get a friend to cut it and weld a new one on or replace the pipe. Still should probably pull apart that variator and find out why the weight arms don’t move so well. I personally think it’s variating appropriately, but I worry about one weight’s hinge being stiffer than the other’s, causing an imbalance/ extra vibrations. This thing rips super hard! My Instagram is snclvn if you want to see a little clip of it running.
  Peugeot Vogue / 103 Variator questionTopic by: Sean Colvin Sean Colvin 10/14/19 06:28PM
  Re: Peugeot Vogue / 103 Variator questionRe: Rebel Moby Rebel Moby 10/14/19 07:29PM
  Re: Peugeot Vogue / 103 Variator questionRe: Sean Colvin Sean Colvin 10/14/19 08:15PM
  Re: Peugeot Vogue / 103 Variator questionRe: Born to be WillD Born to be WillD 10/14/19 09:56PM
  Re: Peugeot Vogue / 103 Variator questionRe: Sean Colvin Sean Colvin 10/15/19 07:29AM
  Re: Peugeot Vogue / 103 Variator questionRe: LL danktip LL danktip 10/14/19 10:09PM
  Re: Peugeot Vogue / 103 Variator questionRe: Stephen Simmons Stephen Simmons 10/15/19 05:52AM
  Re: Peugeot Vogue / 103 Variator questionRe: pat splat pat splat 10/14/19 10:29PM
  Re: Peugeot Vogue / 103 Variator questionRe: cheetahchrome . cheetahchrome . 10/15/19 12:09AM
  Re: Peugeot Vogue / 103 Variator questionRe: Stephen Simmons Stephen Simmons 10/15/19 05:55AM
  Re: Peugeot Vogue / 103 Variator questionRe: jumpsuit steve jumpsuit steve 10/18/19 08:35AM
  Re: Peugeot Vogue / 103 Variator questionRe: Rebel Moby Rebel Moby 10/18/19 09:41AM
  Re: Peugeot Vogue / 103 Variator questionRe: Sean Colvin Sean Colvin 10/18/19 09:54AM
  Re: Peugeot Vogue / 103 Variator questionRe: Rebel Moby Rebel Moby 10/18/19 09:59AM
  Re: Peugeot Vogue / 103 Variator questionRe: cheetahchrome . cheetahchrome . 10/18/19 10:32AM
  Re: Peugeot Vogue / 103 Variator questionRe: Sean Colvin Sean Colvin 10/18/19 01:14PM
  Re: Peugeot Vogue / 103 Variator questionRe: cheetahchrome . cheetahchrome . 10/18/19 07:37PM
  Re: Peugeot Vogue / 103 Variator questionRe: Sean Colvin Sean Colvin 10/18/19 07:28PM
  Re: Peugeot Vogue / 103 Variator questionRe: cheetahchrome . cheetahchrome . 10/18/19 10:14PM
  Re: Peugeot Vogue / 103 Variator questionRe: Sean Colvin Sean Colvin 10/18/19 11:12PM
