Re: Peugeot Vogue / 103 Variator question
Rebel Moby /
Yes the hinge for the flyweights are supposed to be free to move but not to rattle.
Frenchies are a bit temperamental at first to get running sweet, but when you get them set up they are so super excellent to ride.
> Sean Colvin Wrote:
> Took the variator apart, the movable cheek was indeed stuck on the hub.
> Cleaned it out and lightly sanded down the surfaces and it’s moving
> pretty good now. The weights are moving, but not loosely. Their is some
> resistance that feels like it’s built-in. In your experience, are those
> hinges supposed to be nice and loose? It’s variating now and the movable
> cheek is going back into its resting position. The engine is shaking
> pretty violently at high rpms so I’ll have to dial that in. Belt tension
> is good, spring tension feels right. I’ll be back at it tonight and this
> weekend.
  Peugeot Vogue / 103 Variator questionTopic by: Sean Colvin Sean Colvin 10/14/19 06:28PM
  Re: Peugeot Vogue / 103 Variator questionRe: Rebel Moby Rebel Moby 10/14/19 07:29PM
  Re: Peugeot Vogue / 103 Variator questionRe: Sean Colvin Sean Colvin 10/14/19 08:15PM
  Re: Peugeot Vogue / 103 Variator questionRe: Born to be WillD Born to be WillD 10/14/19 09:56PM
  Re: Peugeot Vogue / 103 Variator questionRe: Sean Colvin Sean Colvin 10/15/19 07:29AM
  Re: Peugeot Vogue / 103 Variator questionRe: LL danktip LL danktip 10/14/19 10:09PM
  Re: Peugeot Vogue / 103 Variator questionRe: Stephen Simmons Stephen Simmons 10/15/19 05:52AM
  Re: Peugeot Vogue / 103 Variator questionRe: pat splat pat splat 10/14/19 10:29PM
  Re: Peugeot Vogue / 103 Variator questionRe: cheetahchrome . cheetahchrome . 10/15/19 12:09AM
  Re: Peugeot Vogue / 103 Variator questionRe: Stephen Simmons Stephen Simmons 10/15/19 05:55AM
  Re: Peugeot Vogue / 103 Variator questionRe: jumpsuit steve jumpsuit steve 10/18/19 08:35AM
  Re: Peugeot Vogue / 103 Variator questionRe: Rebel Moby Rebel Moby 10/18/19 09:41AM
  Re: Peugeot Vogue / 103 Variator questionRe: Sean Colvin Sean Colvin 10/18/19 09:54AM
  Re: Peugeot Vogue / 103 Variator questionRe: Rebel Moby Rebel Moby 10/18/19 09:59AM
  Re: Peugeot Vogue / 103 Variator questionRe: cheetahchrome . cheetahchrome . 10/18/19 10:32AM
  Re: Peugeot Vogue / 103 Variator questionRe: Sean Colvin Sean Colvin 10/18/19 01:14PM
  Re: Peugeot Vogue / 103 Variator questionRe: cheetahchrome . cheetahchrome . 10/18/19 07:37PM
  Re: Peugeot Vogue / 103 Variator questionRe: Sean Colvin Sean Colvin 10/18/19 07:28PM
  Re: Peugeot Vogue / 103 Variator questionRe: cheetahchrome . cheetahchrome . 10/18/19 10:14PM
  Re: Peugeot Vogue / 103 Variator questionRe: Sean Colvin Sean Colvin 10/18/19 11:12PM
