Re: Peugeot Vogue / 103 Variator question
Sean Colvin /
Took the variator apart, the movable cheek was indeed stuck on the hub. Cleaned it out and lightly sanded down the surfaces and it’s moving pretty good now. The weights are moving, but not loosely. Their is some resistance that feels like it’s built-in. In your experience, are those hinges supposed to be nice and loose? It’s variating now and the movable cheek is going back into its resting position. The engine is shaking pretty violently at high rpms so I’ll have to dial that in. Belt tension is good, spring tension feels right. I’ll be back at it tonight and this weekend.
  Peugeot Vogue / 103 Variator questionTopic by: Sean Colvin Sean Colvin 10/14/19 06:28PM
  Re: Peugeot Vogue / 103 Variator questionRe: Rebel Moby Rebel Moby 10/14/19 07:29PM
  Re: Peugeot Vogue / 103 Variator questionRe: Sean Colvin Sean Colvin 10/14/19 08:15PM
  Re: Peugeot Vogue / 103 Variator questionRe: Born to be WillD Born to be WillD 10/14/19 09:56PM
  Re: Peugeot Vogue / 103 Variator questionRe: Sean Colvin Sean Colvin 10/15/19 07:29AM
  Re: Peugeot Vogue / 103 Variator questionRe: LL danktip LL danktip 10/14/19 10:09PM
  Re: Peugeot Vogue / 103 Variator questionRe: Stephen Simmons Stephen Simmons 10/15/19 05:52AM
  Re: Peugeot Vogue / 103 Variator questionRe: pat splat pat splat 10/14/19 10:29PM
  Re: Peugeot Vogue / 103 Variator questionRe: cheetahchrome . cheetahchrome . 10/15/19 12:09AM
  Re: Peugeot Vogue / 103 Variator questionRe: Stephen Simmons Stephen Simmons 10/15/19 05:55AM
  Re: Peugeot Vogue / 103 Variator questionRe: jumpsuit steve jumpsuit steve 10/18/19 08:35AM
  Re: Peugeot Vogue / 103 Variator questionRe: Rebel Moby Rebel Moby 10/18/19 09:41AM
  Re: Peugeot Vogue / 103 Variator questionRe: Sean Colvin Sean Colvin 10/18/19 09:54AM
  Re: Peugeot Vogue / 103 Variator questionRe: Rebel Moby Rebel Moby 10/18/19 09:59AM
  Re: Peugeot Vogue / 103 Variator questionRe: cheetahchrome . cheetahchrome . 10/18/19 10:32AM
  Re: Peugeot Vogue / 103 Variator questionRe: Sean Colvin Sean Colvin 10/18/19 01:14PM
  Re: Peugeot Vogue / 103 Variator questionRe: cheetahchrome . cheetahchrome . 10/18/19 07:37PM
  Re: Peugeot Vogue / 103 Variator questionRe: Sean Colvin Sean Colvin 10/18/19 07:28PM
  Re: Peugeot Vogue / 103 Variator questionRe: cheetahchrome . cheetahchrome . 10/18/19 10:14PM
  Re: Peugeot Vogue / 103 Variator questionRe: Sean Colvin Sean Colvin 10/18/19 11:12PM
