Re: Peugeot Vogue / 103 Variator question
Sean Colvin /
Ohhhh, that seems so simple now. I am having an issue with the variator where it will not fully open again after variating. I also think the variator has too much play (about 1mm in and out). I assume those parts have just not moved in a long time and need some oiling but so far on blaster has not done the trick. It seems I’ll need to tear it apart and add a shim. I’m a little foggy on where exactly the shim should go within the variator. Thank you!
  Peugeot Vogue / 103 Variator questionTopic by: Sean Colvin Sean Colvin 10/14/19 06:28PM
  Re: Peugeot Vogue / 103 Variator questionRe: Rebel Moby Rebel Moby 10/14/19 07:29PM
  Re: Peugeot Vogue / 103 Variator questionRe: Sean Colvin Sean Colvin 10/14/19 08:15PM
  Re: Peugeot Vogue / 103 Variator questionRe: Born to be WillD Born to be WillD 10/14/19 09:56PM
  Re: Peugeot Vogue / 103 Variator questionRe: Sean Colvin Sean Colvin 10/15/19 07:29AM
  Re: Peugeot Vogue / 103 Variator questionRe: LL danktip LL danktip 10/14/19 10:09PM
  Re: Peugeot Vogue / 103 Variator questionRe: Stephen Simmons Stephen Simmons 10/15/19 05:52AM
  Re: Peugeot Vogue / 103 Variator questionRe: pat splat pat splat 10/14/19 10:29PM
  Re: Peugeot Vogue / 103 Variator questionRe: cheetahchrome . cheetahchrome . 10/15/19 12:09AM
  Re: Peugeot Vogue / 103 Variator questionRe: Stephen Simmons Stephen Simmons 10/15/19 05:55AM
  Re: Peugeot Vogue / 103 Variator questionRe: jumpsuit steve jumpsuit steve 10/18/19 08:35AM
  Re: Peugeot Vogue / 103 Variator questionRe: Rebel Moby Rebel Moby 10/18/19 09:41AM
  Re: Peugeot Vogue / 103 Variator questionRe: Sean Colvin Sean Colvin 10/18/19 09:54AM
  Re: Peugeot Vogue / 103 Variator questionRe: Rebel Moby Rebel Moby 10/18/19 09:59AM
  Re: Peugeot Vogue / 103 Variator questionRe: cheetahchrome . cheetahchrome . 10/18/19 10:32AM
  Re: Peugeot Vogue / 103 Variator questionRe: Sean Colvin Sean Colvin 10/18/19 01:14PM
  Re: Peugeot Vogue / 103 Variator questionRe: cheetahchrome . cheetahchrome . 10/18/19 07:37PM
  Re: Peugeot Vogue / 103 Variator questionRe: Sean Colvin Sean Colvin 10/18/19 07:28PM
  Re: Peugeot Vogue / 103 Variator questionRe: cheetahchrome . cheetahchrome . 10/18/19 10:14PM
  Re: Peugeot Vogue / 103 Variator questionRe: Sean Colvin Sean Colvin 10/18/19 11:12PM
