Re: 15mm Bing clone issue
Jeff Parr /
My findings
First. the Bing 15mm clone has some poor machining and needs small corrections done to it. Remove the carb and strip it down then run the top of the carb over a wet stone till it nice and smooth then clean the hell out of it.
Second. The clone carb top is thinner than the OEM so the clone top will bow a small amount when it’s tightened up so if you have a OEM top use it.
Third. Both the OEM and the clone top gaskets are really thin so buy them in two’s and double stack them for a leak free carb.
I also started making my own intake gaskets since the Treats gaskets are thin and junk.
