Re: 15mm Bing clone issue
Jeff Parr /
> P D Wrote:
> > Jeff Parr Wrote:
> > I was just wondering aboot the carb top, Is the clone top poorly cast
> > and need to be worked as well or will the gasket seal it off?
> You might get away with a gasket , but , I'd just flatten that top first
> and be done with it .
I was thinking of using two gaskets for a better seal. the clone and the OEM are really too thin so the crush bad in some areas.
