15mm Bing clone issue
Jeff Parr /
I have found a problem with Bing clone carbs that I figured I would pass on to others. The machine work is poor and needs small fix’s so here’s a fix I found.
I was having problems with vacuum leaks between the carb top and the top of the carb even with a two gaskets on it so found I put the carb on a wet stone and worked at back & forth till it was flat. With luck this will fix it and it might help others.
