Where and what does a rectifer and a load resister look like?
Ken Powers /
84 General 5 Star
what does a load resister look like on this bike and what and where is the rectifier?
I am working on rewiring a torn up hack job of this bikes electrical and am not sure what I'm looking for. Your help (particularly with pictures) would greatly assist.
kap
Re: Where and what does a rectifer and a load resister look like?
Ken Powers /
Located the rectifier and cleaned it but it appears the resister has been removed from the system (?) I do have existing open bare wires too
♣Slew Foot♣ /
The resistor is located either in the tail light housing or it is inside of the headlight in the wiring block it's used the lower the wattage for the running light the other rectifier is usually nonexistent on a 6 volt system what it does is the sax has such a low output the stock bulbs for the tail were 5 Watt + 3 and the headlight was only 18w.
If it had an aftermarket battery and turnsignals the battery functions as both.
