Re: Am I four-stroking? And what to do about it
P D /
> Drew Cooper Wrote:
> So I put the old carburetor back after what I think was a good cleaning,
> and it stopped bogging at full throttle but still only went 25. I
> noticed an air leak (detected with starting fluid; engine died when I
> applied it to the intake manifold) which applying some Permatex seemed
> to fix. Any issues with top speed should be with the engine itself at
> this point, right?
Not necessarily . Once the motor runs 'good' ( tuned to factory specs ) , then the rest of the machine has to be made to 'run' as good .
>Stock air filter in place .
>Exhaust tight and clean inside . I use cheap oven cleaner which seems to do a good job . I have burned the exhaust out with straight gasoline , but , that can get real exciting very quickly ( don't do it ) . I've heard that drain cleaner does a decent job .
>Transmission has to be copacetic with proper oil applied . I have tried many different oils and have found that 15w-40 diesel oil seems to produce the best results . It should be noted that the best results may not be seen immediately because of 'deposits' left from previous oils .
>The wheels have to be free rolling/spinning ( correct lubed bearings ) with no brake drag .
Obviously , the rear wheel will have a bit more drag when on stand , due to transmission interaction .
Those last few MPHs are the hardest to have .
Always remember that it's the little things that make the big things run . ;)
  Am I four-stroking? And what to do about itTopic by: Drew Cooper Drew Cooper 10/12/19 04:36PM
  Re: Am I four-stroking? And what to do about itRe: pat splat pat splat 10/12/19 04:44PM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/12/19 04:48PM
  Re: Am I four-stroking? And what to do about itRe: P D P D 10/12/19 05:32PM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/12/19 06:02PM
  Re: Am I four-stroking? And what to do about itRe: Daniel '' Daniel '' 10/12/19 11:10PM
  Re: Am I four-stroking? And what to do about itRe: Don Ohio Don Ohio 10/13/19 02:15PM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/13/19 03:19PM
  Re: Am I four-stroking? And what to do about itRe: Don Ohio Don Ohio 10/13/19 08:16PM
  Re: Am I four-stroking? And what to do about itRe: Jeffrey Strichart Jeffrey Strichart 10/13/19 10:03PM
  Re: Am I four-stroking? And what to do about itRe: Don Ohio Don Ohio 10/13/19 11:28PM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/13/19 10:03PM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/13/19 10:16PM
  Re: Am I four-stroking? And what to do about itRe: Jeffrey Strichart Jeffrey Strichart 10/13/19 10:54PM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/14/19 09:46AM
  Re: Am I four-stroking? And what to do about itRe: Jeffrey Strichart Jeffrey Strichart 10/14/19 10:10AM
  Re: Am I four-stroking? And what to do about itRe: P D P D 10/14/19 11:03AM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/14/19 11:27AM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/14/19 11:33AM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/14/19 05:09PM
  Re: Am I four-stroking? And what to do about itRe: P D P D 10/14/19 05:44PM
  Re: Am I four-stroking? And what to do about itRe: Jeffrey Strichart Jeffrey Strichart 10/16/19 01:39AM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/15/19 03:24PM
  Re: Am I four-stroking? And what to do about itRe: Jeffrey Strichart Jeffrey Strichart 10/16/19 01:43AM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/15/19 10:38PM
  Re: Am I four-stroking? And what to do about itRe: P D P D 10/16/19 09:27AM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/17/19 05:16PM
  Re: Am I four-stroking? And what to do about itRe: P D P D 10/17/19 06:38PM
  Re: Am I four-stroking? And what to do about itRe: ken gilbert ken gilbert 10/18/19 11:24AM
  Re: Am I four-stroking? And what to do about itRe: Rebel Moby Rebel Moby 10/18/19 03:16PM
  Re: Am I four-stroking? And what to do about itRe: ken gilbert ken gilbert 10/21/19 06:35AM
