Re: Am I four-stroking? And what to do about it
P D /
An FA50 uses an automatic fuel valve ( petcock ) .
Unless something is not right or it has been replaced with a different style , anytime the motor is not running or being turned over , fuel will not pass until it is switched to the prime position .
If the carb is leaking out of the drain at the bottom of the bowl : the float may be stuck ; the float valve may be dirty ; the drain screw might need attention or the brass over flow tube could be cracked .
In stock configuration , the FA50 runs best with a OEM type foam air filter set up and the carb adjusted per the manual , exactly .
My FA50 started first kick , most often , and held 30+MPH for as long as I cared to ride , when it was totally stock .
Now , technically , it isn't completely stock : less 1 ring and the piston crown has been 'channeled' which lowered the compression a bit slightly quickened transfer and exhaust flow . The carb has been adjusted to accommodate the changes and the bike does as much as 34 - 35 MPH . The piston and rings are due for replacement as both have about 8,000 miles of pretty hard riding .
  Am I four-stroking? And what to do about itTopic by: Drew Cooper Drew Cooper 10/12/19 04:36PM
  Re: Am I four-stroking? And what to do about itRe: pat splat pat splat 10/12/19 04:44PM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/12/19 04:48PM
  Re: Am I four-stroking? And what to do about itRe: P D P D 10/12/19 05:32PM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/12/19 06:02PM
  Re: Am I four-stroking? And what to do about itRe: Daniel '' Daniel '' 10/12/19 11:10PM
  Re: Am I four-stroking? And what to do about itRe: Don Ohio Don Ohio 10/13/19 02:15PM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/13/19 03:19PM
  Re: Am I four-stroking? And what to do about itRe: Don Ohio Don Ohio 10/13/19 08:16PM
  Re: Am I four-stroking? And what to do about itRe: Jeffrey Strichart Jeffrey Strichart 10/13/19 10:03PM
  Re: Am I four-stroking? And what to do about itRe: Don Ohio Don Ohio 10/13/19 11:28PM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/13/19 10:03PM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/13/19 10:16PM
  Re: Am I four-stroking? And what to do about itRe: Jeffrey Strichart Jeffrey Strichart 10/13/19 10:54PM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/14/19 09:46AM
  Re: Am I four-stroking? And what to do about itRe: Jeffrey Strichart Jeffrey Strichart 10/14/19 10:10AM
  Re: Am I four-stroking? And what to do about itRe: P D P D 10/14/19 11:03AM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/14/19 11:27AM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/14/19 11:33AM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/14/19 05:09PM
  Re: Am I four-stroking? And what to do about itRe: P D P D 10/14/19 05:44PM
  Re: Am I four-stroking? And what to do about itRe: Jeffrey Strichart Jeffrey Strichart 10/16/19 01:39AM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/15/19 03:24PM
  Re: Am I four-stroking? And what to do about itRe: Jeffrey Strichart Jeffrey Strichart 10/16/19 01:43AM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/15/19 10:38PM
  Re: Am I four-stroking? And what to do about itRe: P D P D 10/16/19 09:27AM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/17/19 05:16PM
  Re: Am I four-stroking? And what to do about itRe: P D P D 10/17/19 06:38PM
  Re: Am I four-stroking? And what to do about itRe: ken gilbert ken gilbert 10/18/19 11:24AM
  Re: Am I four-stroking? And what to do about itRe: Rebel Moby Rebel Moby 10/18/19 03:16PM
  Re: Am I four-stroking? And what to do about itRe: ken gilbert ken gilbert 10/21/19 06:35AM
