Re: Am I four-stroking? And what to do about it
Jeffrey Strichart /
> Drew Cooper Wrote:
> I don’t have a primer button. There’s a prime lever on the fuelcock but
> I only had to use that when I first replaced the carburetor.
Gotcha. Obviously it should not leak out of the overflow for no apparent reason.
Check your carburetor for plugged jets or incorrect float setting. If the jet(s) are plugged even a little it will not run right and gas would accumulate in the bowl while the engine is running and overflow. If the float is not properly set it would fill up and overflow while the bike is parked (if the petcock is on). Turn the petcock to off and empty the bowl. Then turn the petcock back on. If it does not overflow while parked then the float should be ok. Also a faulty petcock could cause a problem but that is rare.
  Am I four-stroking? And what to do about itTopic by: Drew Cooper Drew Cooper 10/12/19 04:36PM
  Re: Am I four-stroking? And what to do about itRe: pat splat pat splat 10/12/19 04:44PM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/12/19 04:48PM
  Re: Am I four-stroking? And what to do about itRe: P D P D 10/12/19 05:32PM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/12/19 06:02PM
  Re: Am I four-stroking? And what to do about itRe: Daniel '' Daniel '' 10/12/19 11:10PM
  Re: Am I four-stroking? And what to do about itRe: Don Ohio Don Ohio 10/13/19 02:15PM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/13/19 03:19PM
  Re: Am I four-stroking? And what to do about itRe: Don Ohio Don Ohio 10/13/19 08:16PM
  Re: Am I four-stroking? And what to do about itRe: Jeffrey Strichart Jeffrey Strichart 10/13/19 10:03PM
  Re: Am I four-stroking? And what to do about itRe: Don Ohio Don Ohio 10/13/19 11:28PM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/13/19 10:03PM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/13/19 10:16PM
  Re: Am I four-stroking? And what to do about itRe: Jeffrey Strichart Jeffrey Strichart 10/13/19 10:54PM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/14/19 09:46AM
  Re: Am I four-stroking? And what to do about itRe: Jeffrey Strichart Jeffrey Strichart 10/14/19 10:10AM
  Re: Am I four-stroking? And what to do about itRe: P D P D 10/14/19 11:03AM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/14/19 11:27AM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/14/19 11:33AM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/14/19 05:09PM
  Re: Am I four-stroking? And what to do about itRe: P D P D 10/14/19 05:44PM
  Re: Am I four-stroking? And what to do about itRe: Jeffrey Strichart Jeffrey Strichart 10/16/19 01:39AM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/15/19 03:24PM
  Re: Am I four-stroking? And what to do about itRe: Jeffrey Strichart Jeffrey Strichart 10/16/19 01:43AM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/15/19 10:38PM
  Re: Am I four-stroking? And what to do about itRe: P D P D 10/16/19 09:27AM
  Re: Am I four-stroking? And what to do about itRe: Drew Cooper Drew Cooper 10/17/19 05:16PM
  Re: Am I four-stroking? And what to do about itRe: P D P D 10/17/19 06:38PM
  Re: Am I four-stroking? And what to do about itRe: ken gilbert ken gilbert 10/18/19 11:24AM
  Re: Am I four-stroking? And what to do about itRe: Rebel Moby Rebel Moby 10/18/19 03:16PM
  Re: Am I four-stroking? And what to do about itRe: ken gilbert ken gilbert 10/21/19 06:35AM
