Had to take the whole trans apart because some retard who designed it put a loose piece of wire called a "sprag clip" in there. Smart move. Then go to put it back together, now it won't fucking pedal forward and sounds like the trans is about to fall apart when you decel. For a 50cc 2 stroke, they figured out how to make it complicated enough to be garbage. Good job Tomos, no wonder you went out of business..
