Re: Will only idle with the choke held in
Rebel Moby /
Disconnect the fuel line and see if the fuel is actually flowing or if it is dripping in both RUN and RES setting of the petcock. Try gently blowing some air up the fuel line with a hand tire pump in both RUN and RES and see if it flows better.
