Re: Will only idle with the choke held in
♣Slew Foot♣ /
Is it idles with the brake held then the front brake it's an outage bulb or a cracked resistor in the tail light housing also if your horn buzzes all the time or doesn't work it will give you problems a clogged exhaust or petcock but doubtful
