Re: How ,'wet' should the spark plug be when testing fuel delivery?
Rebel Moby /
Stock Honda carb? Did you clean the emulsion tube (the extremely small holes in the side of the tube)
If the carb weeps or spills when cranking then either your float is way to high, dirt on the float valve seat, or it is blowing back because the reeds are not sealing.
