Is my dr cyl done for?
Is my dr done for with these scratch chips?
I'm waiting on a new piston.
Re: Is my dr cyl done for?
shoulda posted b4 order, its done
somebody who's good can put it on a rod hone and clean it up but it might cost less to buy new one with piston/ring.
Alright, thanks.
I would dremil the ports and then run a hone through it. Definitely looks fixable.
Agreed . I'd just clean it and chamfer all edges . New piston , rings and run it .
yea your major gouges are below the transfers so it's not fucking with timing. as long as you get it smooth enough to not catch a ring and really catastrophically destroy everything, you're OK.
Thanks everyone!
I sanded it down and just like that, good as new!
How did that happen?
What's going on down at the bottom of the bore?
Your moped got fked by the long dck of the crank
Richard Eberline /
Piston was put in backass wrong, another I want to it.
I think one of the piston clips came off and took a tour inside the cylinder
You think it was a circlip? You need to be finding out for sure. Were both the circlips in their positions and accounted for?
That gouge in that port looks to me like something fatter than a circlip. More like a Rod big end needle,
What ever it was could now be sitting in your crank case buying another ticket .
