Re: Puch maxi oil leak help
Mike Boyd /
You should remove the cylinder and piston and see if you have a needle bearing in the small end of the conrod, or if you want just open up the cases and see what crank you have. If it's stock I always upgrade if I'm putting on new bearings and seals anyway
