Re: A35 goes fast! but not with me on it
♣Slew Foot♣ /
When you put it together make sure that the can opener shaped thingy on the pedal shaft is in between the case halves in the hour glass. Shaped hole when you put it together or else it won't kick start or pedal forward right also make sure that both of those washers are on the pedal shaft they're crucial if you adjust the thickness of those it will make it pedal better or worse depending stock is usually good when you go to put it on put the bearing the small one that goes on the crank on the crank gently tapping until it's flush if it's in the case leave it in when you put it back together if you have it all right it shouldn't be hard to put together you don't want to greatly Force anyting you want to gently wiggle stuff and it should just fall in place
  A35 goes fast! but not with me on itTopic by: Tobi Lizzi Tobi Lizzi 10/09/19 10:18PM
  Re: A35 goes fast! but not with me on itRe: ♣Slew Foot♣ ♣Slew Foot♣ 10/10/19 12:02AM
  Re: A35 goes fast! but not with me on itRe: Tobi Lizzi Tobi Lizzi 10/10/19 02:33AM
  Re: A35 goes fast! but not with me on itRe: Tobi Lizzi Tobi Lizzi 10/10/19 02:46AM
  Re: A35 goes fast! but not with me on itRe: ♣Slew Foot♣ ♣Slew Foot♣ 10/10/19 07:55PM
  Re: A35 goes fast! but not with me on itRe: ♣Slew Foot♣ ♣Slew Foot♣ 10/10/19 08:00PM
  Re: A35 goes fast! but not with me on itRe: Tobi Lizzi Tobi Lizzi 10/10/19 08:24PM
  Re: A35 goes fast! but not with me on itRe: EH FCC of the QCB EH FCC of the QCB 10/10/19 10:40PM
  Re: A35 goes fast! but not with me on itRe: pat splat pat splat 10/10/19 01:27PM
  Re: A35 goes fast! but not with me on itRe: Stephen Simmons Stephen Simmons 10/10/19 03:34PM
  Re: A35 goes fast! but not with me on itRe: Tobi Lizzi Tobi Lizzi 10/10/19 08:20PM
  Re: A35 goes fast! but not with me on itRe: ♣Slew Foot♣ ♣Slew Foot♣ 10/10/19 10:22PM
  Re: A35 goes fast! but not with me on itRe: ♣Slew Foot♣ ♣Slew Foot♣ 10/10/19 10:25PM
  Re: A35 goes fast! but not with me on itRe: Tobi Lizzi Tobi Lizzi 10/10/19 10:30PM
  Re: A35 goes fast! but not with me on itRe: ♣Slew Foot♣ ♣Slew Foot♣ 10/11/19 04:16AM
  Re: A35 goes fast! but not with me on itRe: Tobi Lizzi Tobi Lizzi 10/13/19 03:51PM
  Re: A35 goes fast! but not with me on itRe: ♣Slew Foot♣ ♣Slew Foot♣ 10/14/19 12:05AM
  Re: A35 goes fast! but not with me on itRe: Tobi Lizzi Tobi Lizzi 10/14/19 01:53PM
  Re: A35 goes fast! but not with me on itRe: Tobi Lizzi Tobi Lizzi 10/13/19 05:30PM
  Re: A35 goes fast! but not with me on itRe: ♣Slew Foot♣ ♣Slew Foot♣ 10/15/19 12:28AM
  Re: A35 goes fast! but not with me on itRe: Tobi Lizzi Tobi Lizzi 10/15/19 10:12PM
  Re: A35 goes fast! but not with me on itRe: mark barney mark barney 02/17/20 08:47PM
  Re: A35 goes fast! but not with me on itRe: ♣Slew Foot♣ ♣Slew Foot♣ 02/17/20 09:20PM
  Re: A35 goes fast! but not with me on itRe: Mark Barney Mark Barney 10/18/19 07:49PM
  Re: A35 goes fast! but not with me on itRe: Tobi Lizzi Tobi Lizzi 10/18/19 08:59PM
  Re: A35 goes fast! but not with me on itRe: ♣Slew Foot♣ ♣Slew Foot♣ 10/19/19 01:56AM
  Re: A35 goes fast! but not with me on itRe: Tobi Lizzi Tobi Lizzi 10/19/19 12:34PM
  Re: A35 goes fast! but not with me on itRe: ♣Slew Foot♣ ♣Slew Foot♣ 10/19/19 02:07PM
  Re: A35 goes fast! but not with me on itRe: pat splat pat splat 10/19/19 10:06PM
  Re: A35 goes fast! but not with me on itRe: ♣Slew Foot♣ ♣Slew Foot♣ 10/20/19 06:10AM
  Re: A35 goes fast! but not with me on itRe: Tobi Lizzi Tobi Lizzi 10/20/19 02:05PM
  Re: A35 goes fast! but not with me on itRe: Tobi Lizzi Tobi Lizzi 10/20/19 02:02PM
  Re: A35 goes fast! but not with me on itRe: ♣Slew Foot♣ ♣Slew Foot♣ 10/20/19 05:29PM
  Re: A35 goes fast! but not with me on itRe: pat splat pat splat 10/30/19 05:52AM
  Re: A35 goes fast! but not with me on itRe: pat splat pat splat 11/13/19 06:04PM
  Re: A35 goes fast! but not with me on itRe: Nicolas Smolders Nicolas Smolders 10/21/19 04:21PM
  Re: A35 goes fast! but not with me on itRe: Nicolas Smolders Nicolas Smolders 10/21/19 04:46PM
  Re: A35 goes fast! but not with me on itRe: Tobi Lizzi Tobi Lizzi 10/21/19 11:59PM
  Re: A35 goes fast! but not with me on itRe: P D P D 10/22/19 10:37AM
  Re: A35 goes fast! but not with me on itRe: Tobi Lizzi Tobi Lizzi 10/27/19 11:23PM
  Re: A35 goes fast! but not with me on itRe: ken gilbert ken gilbert 10/28/19 06:43AM
  Re: A35 goes fast! but not with me on itRe: Tobi Lizzi Tobi Lizzi 10/28/19 09:56AM
  Re: A35 goes fast! but not with me on itRe: Richard Eberline Richard Eberline 10/28/19 08:10AM
  Re: A35 goes fast! but not with me on itRe: Tobi Lizzi Tobi Lizzi 10/28/19 09:59AM
  Re: A35 goes fast! but not with me on itRe: Mike M Mike M 10/29/19 09:40AM
  Re: A35 goes fast! but not with me on itRe: Tobi Lizzi Tobi Lizzi 10/29/19 10:11AM
  Re: A35 goes fast! but not with me on itRe: Tobi Lizzi Tobi Lizzi 11/12/19 01:40AM
  Re: A35 goes fast! but not with me on itRe: P D P D 11/12/19 08:06AM
  Re: A35 goes fast! but not with me on itRe: ♣Slew Foot♣ ♣Slew Foot♣ 11/12/19 06:47PM
  Re: A35 goes fast! but not with me on itRe: Tobi Lizzi Tobi Lizzi 11/12/19 09:11PM
  Re: A35 goes fast! but not with me on itRe: Tobi Lizzi Tobi Lizzi 11/13/19 12:22AM
  Re: A35 goes fast! but not with me on itRe: Tobi Lizzi Tobi Lizzi 11/14/19 08:44PM
  Re: A35 goes fast! but not with me on itRe: Sean Colvin Sean Colvin 11/20/19 06:06PM
  Re: A35 goes fast! but not with me on itRe: Tobi Lizzi Tobi Lizzi 11/20/19 11:17PM
  Re: A35 goes fast! but not with me on itRe: Sean Colvin Sean Colvin 11/21/19 07:18AM
  Re: A35 goes fast! but not with me on itRe: Tobi Lizzi Tobi Lizzi 11/21/19 10:17AM
  Re: A35 goes fast! but not with me on itRe: ♣Slew Foot♣ ♣Slew Foot♣ 11/21/19 01:39PM
  Re: A35 goes fast! but not with me on itRe: ♣Slew Foot♣ ♣Slew Foot♣ 11/21/19 02:59AM
  Re: A35 goes fast! but not with me on itRe: Tobi Lizzi Tobi Lizzi 11/21/19 10:24AM
  Re: A35 goes fast! but not with me on itRe: pat splat pat splat 11/21/19 06:42PM
  Re: A35 goes fast! but not with me on itRe: Tobi Lizzi Tobi Lizzi 11/21/19 10:56PM
  Re: A35 goes fast! but not with me on itRe: ♣Slew Foot♣ ♣Slew Foot♣ 11/22/19 03:02AM
  Re: A35 goes fast! but not with me on itRe: pat splat pat splat 11/22/19 10:11AM
  Re: A35 goes fast! but not with me on itRe: Tobi Lizzi Tobi Lizzi 11/22/19 10:21AM
  Re: A35 goes fast! but not with me on itRe: ♣Slew Foot♣ ♣Slew Foot♣ 11/22/19 06:07PM
  Re: A35 goes fast! but not with me on itRe: ♣Slew Foot♣ ♣Slew Foot♣ 11/22/19 06:09PM
  Re: A35 goes fast! but not with me on itRe: Tobi Lizzi Tobi Lizzi 11/22/19 07:28PM
  Re: A35 goes fast! but not with me on itRe: ♣Slew Foot♣ ♣Slew Foot♣ 11/23/19 08:56AM
  Re: A35 goes fast! but not with me on itRe: Sean Colvin Sean Colvin 11/24/19 11:25AM
  Re: A35 goes fast! but not with me on itRe: pat splat pat splat 11/22/19 12:26PM
  Re: A35 goes fast! but not with me on itRe: Tobi Lizzi Tobi Lizzi 11/22/19 04:08PM
  Re: A35 goes fast! but not with me on itRe: Tobi Lizzi Tobi Lizzi 11/22/19 08:19PM
  Re: A35 goes fast! but not with me on itRe: P D P D 11/23/19 08:09AM
  Re: A35 goes fast! but not with me on itRe: Tobi Lizzi Tobi Lizzi 11/24/19 10:13PM
  Re: A35 goes fast! but not with me on itRe: ♣Slew Foot♣ ♣Slew Foot♣ 11/24/19 10:21PM
  Re: A35 goes fast! but not with me on itRe: pat splat pat splat 11/25/19 02:44PM
