Re: Spark plug mystery
♣Slew Foot♣ /
Okay here's the dealio when you're dealing with a Tomas those two little lines on the case Center your stator on dead center between to start provided you didn't put up thick gasket on the base that should be a safe starting point the problem you're having right now is you do not have enough air the carbs is Tiny so ditch any air box or filter put pantyhose or a t-shirt held by a copper wire or rubber band round of mouth of the carb start with a 74 jet and work down 50 to 1 ratio of istica two-stroke oil that way everything's safe to start if you have a timing light more power to you but it equates the one mmmm of movement on the stator is equal to 1 degree also you can mechanically measure from Top Dead Center as it would be 2 millimeters before top dead center is where you wanted to fire
  Spark plug mysteryTopic by: Drake Abrahamsson Drake Abrahamsson 10/08/19 02:01PM
  Re: Spark plug mysteryRe: alex . alex . 10/08/19 03:04PM
  Re: Spark plug mysteryRe: Drake Abrahamsson Drake Abrahamsson 10/08/19 03:37PM
  Re: Spark plug mysteryRe: Drake Abrahamsson Drake Abrahamsson 10/08/19 03:46PM
  Re: Spark plug mysteryRe: Charles McCusker Charles McCusker 10/08/19 03:57PM
  Re: Spark plug mysteryRe: Drake Abrahamsson Drake Abrahamsson 10/08/19 04:15PM
  Re: Spark plug mysteryRe: Rebel Moby Rebel Moby 10/08/19 04:31PM
  Re: Spark plug mysteryRe: Drake Abrahamsson Drake Abrahamsson 10/08/19 04:46PM
  Re: Spark plug mysteryRe: Probably Fred Probably Fred 10/08/19 05:27PM
  Re: Spark plug mysteryRe: Drake Abrahamsson Drake Abrahamsson 10/08/19 06:47PM
  Re: Spark plug mysteryRe: live ɘvil live ɘvil 10/08/19 08:14PM
  Re: Spark plug mysteryRe: Drake Abrahamsson Drake Abrahamsson 10/08/19 08:20PM
  Re: Spark plug mysteryRe: live ɘvil live ɘvil 10/08/19 09:37PM
  Re: Spark plug mysteryRe: Drake Abrahamsson Drake Abrahamsson 10/08/19 10:42PM
  Re: Spark plug mysteryRe: Den 23 Den 23 10/08/19 06:02PM
  Re: Spark plug mysteryRe: ♣Slew Foot♣ ♣Slew Foot♣ 10/08/19 09:45PM
  Re: Spark plug mysteryRe: Drake Abrahamsson Drake Abrahamsson 10/08/19 10:39PM
  Re: Spark plug mysteryRe: live ɘvil live ɘvil 10/08/19 11:15PM
  Re: Spark plug mysteryRe: Drake Abrahamsson Drake Abrahamsson 10/08/19 11:24PM
  Re: Spark plug mysteryRe: live ɘvil live ɘvil 10/08/19 11:40PM
  Re: Spark plug mysteryRe: Drake Abrahamsson Drake Abrahamsson 10/09/19 12:13AM
  Re: Spark plug mysteryRe: ♣Slew Foot♣ ♣Slew Foot♣ 10/09/19 02:03AM
  Re: Spark plug mysteryRe: Drake Abrahamsson Drake Abrahamsson 10/09/19 12:40PM
  Re: Spark plug mysteryRe: ♣Slew Foot♣ ♣Slew Foot♣ 10/10/19 12:06AM
  Re: Spark plug mysteryRe: Drake Abrahamsson Drake Abrahamsson 10/10/19 02:20AM
  Re: Spark plug mysteryRe: ♣Slew Foot♣ ♣Slew Foot♣ 10/10/19 08:14PM
  Re: Spark plug mysteryRe: Drake Abrahamsson Drake Abrahamsson 10/11/19 02:32AM
  Re: Spark plug mysteryRe: Drake Abrahamsson Drake Abrahamsson 10/08/19 07:42PM
  Re: Spark plug mysteryRe: alex . alex . 10/09/19 01:58PM
  Re: Spark plug mysteryRe: Drake Abrahamsson Drake Abrahamsson 10/09/19 02:21PM
  Re: Spark plug mysteryRe: Don Ohio Don Ohio 10/09/19 02:04PM
  Re: Spark plug mysteryRe: Drake Abrahamsson Drake Abrahamsson 10/09/19 02:19PM
  Re: Spark plug mysteryRe: Drake Abrahamsson Drake Abrahamsson 10/09/19 03:07PM
  Re: Spark plug mysteryRe: alex . alex . 10/09/19 03:23PM
