i only thought of it because it specifically says oil and fuel resistant up to 500 degrees but im not 100% sure what im going for here
not sure if i need to fill the sleeve with epoxy, making it a solid cylinder, then popping it back in before plating the hole off
OR
use a rod of some sort, epoxied into the center of the plastic sleeve, that extends deeper into the shaft itself?
