Re: Tomos targa throttle cable issue
Bob Selby /
You have two solutions to this issue...one buy a new throttle cable and set screw from Treatland...or... pull the throttle cable out of the handlebar control and see how much extra inner cable is left.. see where the set screw has left a mark on cable. Then crazy glue the left over section and let dry...cut the cable cleanly so it will go through the tiny hole. Tighten the set screw in the original spot...
