Clutch actuator problem. Need help.
Jeffrey Strichart /
Puch Maxi 1979. The little lever on the clutch cover to actuate the clutch broke in half. I got a new one and installed it into the clutch cover. I had to take the clutch over off to do it. The problem is I don't know how to orient the actuator. See the pictures. It can go a lot of ways but don't know which way. Thanks.
(edited)
Re: Clutch actuator problem. Need help.
Jeffrey Strichart /
Ps I did look on the wiki and also the shop manual which is not clear.
♣Slew Foot♣ /
At rest the flat shot side should rest against the clutch plate it is a little weird but you have to hold it when reassembling so that it doesn't slip
Jeffrey Strichart /
Thank you. I did try it like that and it didn't work but it probably slipped like you said. Thanks again
I can try to takeing a photo tomorrow of a few different covers.
I would try to mock it up on the motor to try to find the correct position.
♣Slew Foot♣ /
when it's put together right it looks wrong it looks like the little arm is too far forward but that's just the way it is....
Jeffrey Strichart /
Thanks guys. I will give it a go again and report back.
Overpriced Parts /
There are 2 different actuators,
If you have the small actuator one you may need to get the small one or get different starter plate
Jeffrey Strichart /
Today I got it on there working fine. Actually I had it right the very first time but I forgot to tighten the cable so I thought it was not working. Put it back on today and tightened the cable up a bit and it worked. Thanks all.
