Re: Air leak in intake manifold
Brad William /
Put a square of 150 grit or so on a pane of glass and sweep the manifold over the sandpaper being veeeeeery careful hold the flat face of the manifold flat against the sandpaper as you go. After you've got it planed out (check against a straight edge as you go) finish if off with some finer grit.
