Re: Air leak in intake manifold
Jeffrey Strichart /
> a p Wrote:
> if I screw in one side the other side is raised a little
I think the problem is in how he is tightening it. If you screw it down tight on one side first this will happen. You need to tighten them equally at a time. Never tighten one side of anything before the other side(s) are tightened because you will get a leak. Fortunately you can usually fix it by simply starting over and tightening everything evenly.
