Re: Air leak in intake manifold
Daniel '' /
Where is it on the intake. If it’s the flange I would lap the intake and replace the gasket. If it’s at the clamp it’s not the end of the world. Most bings get ovaled on the clamp from being over tightened, if you push it on hard when you tighten it down it will usually cure it enough to not be an issue.
