6v regulator removal
Thanh-Danh Ho /
I'd like to change the QT50 to 12v and from what i've found, it looks like I need to switch the bulbs out to 12v bulbs and remove the regulator.
My question is what do I do with the wire that goes to the regulator? Do I ground it to the frame? Or do I tape it off and not have it connected to anything?
I'm thinking that I need to ground it to the frame, but I'm not sure and I don't want to create a dead short.
Thanks,
TD
Re: 6v regulator removal
Jack Rutherford /
Does the regulator really care whether it's getting 6v or 12v?
Anyhow, you'll need a charge coil that puts out 12v.
Yep, need a 12V ignition first. Why are you trying to change it? If your lights are dim, swap the rear bulbs to LED
