1985 Garelli rally sl replacement stator
Anyone know where to get a stator, missing a coil.
Re: 1985 Garelli rally sl replacement stator
Why not just get the coil?
Which coil is missing?
Moped Lar (OFMC) /
I’ve got a stator off a 1978 gran sport.
The top coil is missing, asssuming why I have no spark lol....
Just as a test , try running a wire from the coil connection below the condenser to the points and see if you get spark . Disconnect the white wire going out of the stator from where it connects outward or use it as a kill wire .
I will try it and let you know
Where do I purchase a coil
And pdcomm there is a yellow wire connected to points and coil already and nothing
u got a flywheel correct? oil that felt pad, clean n set points. what else is missing rear brake light?
> and nothing
Where does the light colored wire from the condenser go ?
And , where does the light colored wire form thhhe only coil on the stator plate go ?
I have a flywheel , took it off because it looked like a wire was frayed and saw two screws loose. That’s when I discovered the top coil in the stator was missing. Yes I have the rear bulb in. Noticed a button in the left brake handle and a wire was loose. Not sure if you have to have the brake pulled.The yellow ( light ) wire run from condenser to coil and also to the points.
. (edited)
