Re: What are the limits to mounting a carb tilted?
Probably Fred /
Ya check fuel flow but I know my mikuni carbs on my magnum Gila builds are basically flat, just little angle and the floats had to be adjusted to the point where they almost leaked or they were fuel starved at hi speed but they are tm24s on big 74cc 8 petal reed cylinders that have 157.5-160 main jets in them
I got fuel flow Galore, I run a huge lawn tractor fuel filter and I actually have a few pounds of pressure due to the tank height to carb distance so could be float if you got good fuel flow,
