Re: Head light and tail light no longer working.
Born to be WillD /
check the frame's grounded to the subframe. that's sometimes an issue for hobbits. Then start tracing wires with a multimeter. I also like to use these:
you can easily track on down the line see if there's power out of the engine, then which wires have power up by the headlight, check grounds etc. super quick easy diagnostic - does this wire have power? yes - ok well plug into headlight, does headlight work? no? headlight's toast. etc
