What I usually do is coat the gasket in Two stroke oil or grease.
(Sometimes WD-40 for convenience).
In some cases where I've had air leaks I'll use a little bit of gasket sealant on the gasket without oiling to fill tiny gaps, it's not ideal but it works. If its wet, its a bit more plyable so it can fill in gaps a little better is my thoughts.
