Re: Ignition system uncertainty
Drake Abrahamsson /
> Overpriced Parts Wrote:
> Read this :
> https://www.mopedarmy.com/wiki/Puch_timing
> it’s not just about timing but it tells you how to service your magneto
I replaced the felt as well as lightly sanded off some pitting on the cam lobe. Sprayed it with some white lithium grease and lightly wiped the excess off. I did this a few weeks ago and it ran better after that because the timing before was jumping all over the place at any RPM higher than idle.
