Re: Oil leak 78 Maxi
Saabsonettguy . /
The cases are split horizontally and sealed with a non hardening liquid sealant. There isn't enough transmission fluid in the case to leak from the case seam when the motor is sitting. It's probably leaking around the clutch cover or drain plug.
