Re: Ignition wire
P D /
Cut 1/4" off that bad end and check the coil connection point for any corrosion . The wire is meant to screw into the coil and be left tight .
You can see the tip of the 'screw' that insures a good connection with the HT wire core on the right hand coil . Note that the image says it's a PUSH IN type , but , it actually requires the wire to be twisted onto that screw .
  Ignition wireTopic by: Drake Abrahamsson Drake Abrahamsson 09/21/19 06:27PM
  Re: Ignition wireRe: P D P D 09/21/19 08:39PM
  Re: Ignition wireRe: pat splat pat splat 09/23/19 04:11PM
