Ignition wire
Drake Abrahamsson /
Just moved and had my moped in the back of a UHaul tied down. Bike was barely running when I tried it to get to school on day 1, could barely idle and no chance at actually running. I accidentally knocked out the ignition wire the next day and it was burnt! Is there any way this could’ve happened in the ignition coil socket thing or did I just leave it to burn on the fins (accidentally) the day before I moved then put it back in without noticing? ALSO how do you all keep your wire in the coil? Mine is loose and it always makes me look like a fool when I can’t start my bike because of it. I did two layers of electrical tape but it eventually crinkles up and I have to replace it which gets annoying. Thanks!
  Ignition wireTopic by: Drake Abrahamsson Drake Abrahamsson 09/21/19 06:27PM
  Re: Ignition wireRe: P D P D 09/21/19 08:39PM
  Re: Ignition wireRe: pat splat pat splat 09/23/19 04:11PM
