Re: 505/1A Running well now, seeking advice on increasing torque.
Ryan Brad /
> Drake Abrahamsson Wrote:
> CC stands for Cubic Centimeter so changing your clutch won’t increase
> your CCs. Single speed engines aren’t great at hills in the first place.
> Air filter won’t help but is good for the bike so nothing that’s not
> supposed to get into your system will get in. You’ll have to rejet
> because you’re messing with the fuel/air mixture. Gear ratios are
> something to look at. You’ll lose some top speed but will gain torque
> therefore hill climbing ability and acceleration from off the block.
> Don’t let kits scare you, they’re arguably same level of complexity as
> fine tuning your clutch.
After putting the air filter on the bike is actually running better than ever since it’s been in my possession and probably about twice as fast uphill as it was without the filter. I’d imagine it was getting way too much air without it, not sure if I should still experiment with the jet or not. Just to be clear I’d have to buy a whole nother jet, bigger / smaller and put it in the carb and just experiment? Re-jetting is not something where you can just adjust the existing jet right??
