Re: Honda Express nc50 1980 Carb
Wild West Pony /
Check your fuel line, damage to the line could cause leaks. Check the fuel line connections. Check your drain screw. If it's out or have missing/damage an o-ring, your bowl will drain. Check your float needle, if it's damaged or misshapen even slightly, almost unnoticeable, it will leak.
You can get a new needle
https://www.treatland.tv/honda-OEM-keihin-carburetor-needle-float-valve-p/oem-needle-valve-16155883005.htm
Drain screw
https://www.treatland.tv/OEM-honda-float-bowl-drain-screw-p/drain-screw-16024-124-760.htm
Or you could get a new carb.
https://www.treatland.tv/honda-express-nc50-na50-carb-XPRESS-YOURSELF-pack-p/express-carb-party-sha.htm
