How do I change all the oil lines on 2005 tomos lx
I was wondering how to change the oil lines because they are just old, I need to know how to put the clamps on and basically everything that any of you can help with.
Re: How do I change all the oil lines on 2005 tomos lx
Dirty30 Dillon /
To do so properly, you should use ear-crimp hose clamps and fresh hose. You need to bleed the system by manually cycling the pump off the motor.
How do I manually cycle the pump off ?
throw it in the trash, plug the oil injection bung n premix, i know u wanna keep it stock.
Dirty30 Dillon /
I haven't messed with a Tomos oil pump that wasn't the newer electric ones, but take the pump off, chuck the end up in a drill and spin it gradually
Could I just pull all the lines of and replace them instead of doing all these things
Overpriced Parts /
> these things
Yes replace the lines but run pre-mix in the tank until pump primes all the lines full of oil,
I do dislike oil pump Tomos but I got one low mi bike with 147 miles on it awhile back for a good price so I replaced the lines,
It took quite a long time of riding before the oil was for in the lines and going into the inlet nipple,
I started out with about 1 quart of gas to oil 50 to 1 ratio in the tank and it took quite a while maybe like 5-6 miles to see oil going to nipple, well that’s when I stopped to look,
I Put cover back on then put straight gas in it and ran it with Polaris synthetic injector oil in oil tank,
Though I don’t use the bike a lot not to keep the mileage low at 1100 miles now but injector still works fine and I’m running straight gas,
Dirty30 Dillon /
> these things
You can do whatever you want.
Running the tank with pre-mix while the pump primes is a great way to potentially burn out your un-primed pump.
It's simple maintenance stuff.
Captain Janeway /
https://drive.google.com/drive/folders/1_XV6hhm02gbGv8vjG857et4q2-iBtmxi
Your manual. Last page talks about oil pump. I don't have this particular model but this discusses line bleeding. Buy new hose and just replace one at a time so you get them in the right place.
Dillon can you say a little more about the newer tomos electric oil pump. Where is the pump located. Is it reliable vs the older type if
Maintained ? Any conversions from mechanical to electric ..etc
Where can I buy the lines for the oil pump and what is the size
If I replace the oil lines how many feet do you think I would need ? I was thinking like 7/8 feet
Treatland.tv
Moped Lar (OFMC) /
Are you making a career out of changing the oil lines?
