> Laine Moses Wrote:
> Could I just run premix till the bubbles go away then drain the premix
> after the bubbles are out and put regular gas in her, but I will put a
> low amount of oil in my mixture
Just disconnect the oil line and get the bubbles out ASAP .
Definitely run premix at normally recommended ratios ( 50 to 1 ) until you know the pump is feeding oil as it should . Then start running start gasoline again . Running a bit too much oil is much better than not enough . ;)
