> Born to be WillD Wrote:
> That's no good. In fact very bad, a bubble in the actual pump is
> probably the biggest cause of fail. Make sure all the hoses are sound,
> no leaks or cracks, and fill the reservoir, disconnect the lines and let
> em bubble out til they're full, no bubbles, and reconnect. run premix
> and run it til oil comes outta the injector steady.
> Or just run premix only
I'll second that^ procedure . I still run the pump , as I don't like the hassle of premixing . I'm too lazy . ;)
I seized a motor when I kinked an oil line and ran the pump dry . It was a very long push home . :(
