Sachs 505 keeps leaking
I cannot figure out why my bike is leaking, I think its from the pedal drive, but as Ive read, it sits ABOVE the oil level, then why does it leak so much?!? Ive split the cases and liquid gasket em. Still leaks til dry. The clutch cover doesnt leak Im pretty sure.
Anyone face this and come out successful?
Re: Sachs 505 keeps leaking
Clean the motor , ride , inspect . Repeat until you see where the leak is coming from .
I've had 2 leak on the pedal shaft. Tomos style auto-chain-lube. Never found a good solution, just kinda live with it, refill trans sometimes.
