open throttle then dies...help
I just put a new carb on my 1977 batavus hs50 . mstarts and idles fine nut when I open the throttle it dies. am I not getting enough compression?
Re: open throttle then dies...help
Have you cleaned the carb? Make sure you have good flow of fuel to and thru that carb. Are you running an air filter? Carb is not loose or in take loose? New spark plug?
Um, did you try playing w jetting or just slap on and expect it to be good? Checked for airleaks?
I got it guys thanks. I did all the above thanks!!
Yer welcome! Glad you got it fixed!
