Re: New to me, 63 Mobyelette AV88
Rebel Moby /
John
Just strip a little section of the grey with net the terminal where it goes into the external coilandsplice the pigtail there into the grey wire.
Output of the cols will be in AC: ~6v for the ignition exciter, ~6v for the 6v terminal and ~12v for the 12v terminal. On the magnetos with two coils the 6v terminal is actually the tail for the ignition exciter, so if that is not connected to the wire harness it will need to be shorted to common (ground). On magnetor with 3 coils there is a separate coil for the 6v accessory.
Check accessory coil(s) and exciter coil with a ohmmeter the value should be 1-2Ω.
> John Ebert Wrote:
> When you say to splice the condenser to the gray wire is there a Y?
> Gray wire to condenser then on to the coil?
> Also is there a way to check the output of the ignition and lighting
> windings?
> Thank you all for your help.
> John in Texas
  New to me, 63 Mobyelette AV88Topic by: John Ebert John Ebert 09/17/19 09:25AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 09/17/19 01:48PM
  Re: New to me, 63 Mobyelette AV88Re: Stephen Keller Stephen Keller 09/17/19 02:07PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 09/17/19 04:52PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 09/17/19 05:39PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 09/18/19 06:42AM
  Re: New to me, 63 Mobyelette AV88Re: Stephen Keller Stephen Keller 09/18/19 02:10PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 09/17/19 05:49PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 09/18/19 06:49AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 09/17/19 05:53PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 09/18/19 06:54AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 09/18/19 06:11PM
  Re: New to me, 63 Mobyelette AV88Re: Kenneth Hill Kenneth Hill 09/19/19 10:26PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 09/20/19 01:34AM
  Re: New to me, 63 Mobyelette AV88Re: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 10/02/19 09:18AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/02/19 01:11PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/02/19 01:16PM
  Re: New to me, 63 Mobyelette AV88Re: P D P D 10/02/19 01:41PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/05/19 05:58PM
  Re: New to me, 63 Mobyelette AV88Re: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 10/03/19 01:45AM
  Re: New to me, 63 Mobyelette AV88Re: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 10/03/19 02:01AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/03/19 04:48PM
  Re: New to me, 63 Mobyelette AV88Re: Aaron Goldman Aaron Goldman 10/20/19 06:57PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/20/19 08:06PM
  Re: New to me, 63 Mobyelette AV88Re: Aaron Goldman Aaron Goldman 10/21/19 06:22AM
  Re: New to me, 63 Mobyelette AV88Re: Brian Terrell Brian Terrell 11/19/19 11:37AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 11/19/19 04:26PM
  Re: New to me, 63 Mobyelette AV88Re: Brian Terrell Brian Terrell 11/19/19 06:10PM
  Re: New to me, 63 Mobyelette AV88Re: Brian Terrell Brian Terrell 11/19/19 11:28PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 11/20/19 05:52AM
  Re: New to me, 63 Mobyelette AV88Re: Rick Bergsma Rick Bergsma 10/02/19 09:16PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/03/19 04:28PM
  Re: New to me, 63 Mobyelette AV88Re: Aaron Blair Aaron Blair 10/03/19 07:25AM
  Re: New to me, 63 Mobyelette AV88Re: Saabsonettguy . Saabsonettguy . 10/04/19 08:02AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/04/19 08:49AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/04/19 09:18AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/04/19 09:29AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/05/19 09:38AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/05/19 10:40AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/06/19 12:05PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/06/19 12:19PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/06/19 12:31PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/08/19 09:04AM
  Re: New to me, 63 Mobyelette AV88Re: P D P D 10/08/19 09:41AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/08/19 10:55AM
  Re: New to me, 63 Mobyelette AV88Re: P D P D 10/08/19 11:14AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/08/19 11:56AM
  Re: New to me, 63 Mobyelette AV88Re: P D P D 10/08/19 01:56PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/08/19 04:45PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/07/19 08:08AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/07/19 11:17AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/07/19 12:15PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/07/19 05:10PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/09/19 09:10AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/15/19 05:46PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/15/19 07:45PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/16/19 05:45AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/16/19 08:54AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/21/19 02:40PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/21/19 07:59PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/22/19 08:12AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/22/19 09:33AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 11/17/19 05:19PM
  Re: New to me, 63 Mobyelette AV88Re: Kenneth Hill Kenneth Hill 12/17/19 08:42AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 12/22/19 04:45PM
  Re: New to me, 63 Mobyelette AV88Re: P D P D 12/22/19 06:05PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 01/06/20 11:04PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 11/02/19 07:13PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 11/04/19 10:32AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 11/16/19 02:21PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 11/16/19 04:04PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 11/16/19 04:51PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 11/16/19 04:58PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 11/17/19 09:56AM
  Re: New to me, 63 Mobyelette AV88Re: pat splat pat splat 01/06/20 11:35PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 01/07/20 08:13AM
  Re: New to me, 63 Mobyelette AV88Re: Kenneth Hill Kenneth Hill 01/07/20 10:42PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 01/08/20 09:44AM
  Re: New to me, 63 Mobyelette AV88Re: Kenneth Hill Kenneth Hill 01/08/20 02:06PM
  Re: New to me, 63 Mobyelette AV88Re: P D P D 01/08/20 03:08PM
  Re: New to me, 63 Mobyelette AV88Re: Kenneth Hill Kenneth Hill 01/08/20 11:20PM
  Re: New to me, 63 Mobyelette AV88Re: P D P D 01/09/20 09:01AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 01/29/20 02:53PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 02/02/20 09:25AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 03/09/20 10:27AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 03/09/20 11:00AM
  Re: New to me, 63 Mobyelette AV88Re: P D P D 03/09/20 11:13AM
  Re: New to me, 63 Mobyelette AV88Re: Kenneth Hill Kenneth Hill 03/10/20 08:38AM
  Re: New to me, 63 Mobyelette AV88Re: Brian Terrell Brian Terrell 03/10/20 09:10AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 03/10/20 09:18AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 03/14/20 10:35AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 03/14/20 11:12AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 03/14/20 11:55AM
  Re: New to me, 63 Mobyelette AV88Re: P D P D 03/14/20 12:08PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 03/14/20 03:37PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 03/14/20 04:19PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 03/15/20 06:14PM
  Re: New to me, 63 Mobyelette AV88Re: Kenneth Hill Kenneth Hill 03/14/20 11:33PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 03/15/20 06:02PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 04/28/20 10:56AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 04/28/20 12:21PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 12/15/20 01:24PM
  Re: New to me, 63 Mobyelette AV88Re: Dirty30 Dillon Dirty30 Dillon 12/15/20 01:34PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 12/15/20 02:21PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 12/16/20 01:45PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 12/18/20 02:29PM
  Re: New to me, 63 Mobyelette AV88Re: Ian T Ian T 04/28/20 03:35PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 04/28/20 04:19PM
