Re: New to me, 63 Mobyelette AV88
Rebel Moby /
If the external Novi coil has a crack in it and seems to be chalky finish on it it will likely be problematic.
ALL Mobys suffer from a crappy bonding strap between the motor and frame. Original is mounted at the upper motor mount long bolt and goes to the external ignition coil's lower stud. Replace that wire with one that runs from one of the intake studs and goes to the external ignition coil's lower stud.
Mobys also have troubles with the condenser, heat is a byproduct of electrical generation in the magneto, heat is the sworn enemy of condensers, Novi 120 magnetos do not have ventilation in the flywheel. Disconnect the original condenser from the points (Blue wire or Blue with black tracer) and remove the old condenser. Get a mid 1960s Delco 6 cylinder condenser (or similar vintage BoschVW condenser) and mount it on the external coil's lower mounting stud (either condenser comes with a handy mounting bracket included). Splice the pigtail to the grey wire that goes to the external coil.
Clean the points with a metal file and flush with brake cleaner or alcohol (sand paper leaves grit behind that can cause arcing on the points, carb cleaner has a lube in it which will cause misfiring so dont use those) and set the points gap at index to 0,4mm. Set the spark initiation at 1,5mm BTDC.
Do not use a resistor plug because the antiparasite plug cap already has a built in resistor.
You now should have a goodly bright blue snappy spark that is strong enough to be seen in just the shadow of the bike.
  New to me, 63 Mobyelette AV88Topic by: John Ebert John Ebert 09/17/19 09:25AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 09/17/19 01:48PM
  Re: New to me, 63 Mobyelette AV88Re: Stephen Keller Stephen Keller 09/17/19 02:07PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 09/17/19 04:52PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 09/17/19 05:39PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 09/18/19 06:42AM
  Re: New to me, 63 Mobyelette AV88Re: Stephen Keller Stephen Keller 09/18/19 02:10PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 09/17/19 05:49PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 09/18/19 06:49AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 09/17/19 05:53PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 09/18/19 06:54AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 09/18/19 06:11PM
  Re: New to me, 63 Mobyelette AV88Re: Kenneth Hill Kenneth Hill 09/19/19 10:26PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 09/20/19 01:34AM
  Re: New to me, 63 Mobyelette AV88Re: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 10/02/19 09:18AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/02/19 01:11PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/02/19 01:16PM
  Re: New to me, 63 Mobyelette AV88Re: P D P D 10/02/19 01:41PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/05/19 05:58PM
  Re: New to me, 63 Mobyelette AV88Re: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 10/03/19 01:45AM
  Re: New to me, 63 Mobyelette AV88Re: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 10/03/19 02:01AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/03/19 04:48PM
  Re: New to me, 63 Mobyelette AV88Re: Aaron Goldman Aaron Goldman 10/20/19 06:57PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/20/19 08:06PM
  Re: New to me, 63 Mobyelette AV88Re: Aaron Goldman Aaron Goldman 10/21/19 06:22AM
  Re: New to me, 63 Mobyelette AV88Re: Brian Terrell Brian Terrell 11/19/19 11:37AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 11/19/19 04:26PM
  Re: New to me, 63 Mobyelette AV88Re: Brian Terrell Brian Terrell 11/19/19 06:10PM
  Re: New to me, 63 Mobyelette AV88Re: Brian Terrell Brian Terrell 11/19/19 11:28PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 11/20/19 05:52AM
  Re: New to me, 63 Mobyelette AV88Re: Rick Bergsma Rick Bergsma 10/02/19 09:16PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/03/19 04:28PM
  Re: New to me, 63 Mobyelette AV88Re: Aaron Blair Aaron Blair 10/03/19 07:25AM
  Re: New to me, 63 Mobyelette AV88Re: Saabsonettguy . Saabsonettguy . 10/04/19 08:02AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/04/19 08:49AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/04/19 09:18AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/04/19 09:29AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/05/19 09:38AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/05/19 10:40AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/06/19 12:05PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/06/19 12:19PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/06/19 12:31PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/08/19 09:04AM
  Re: New to me, 63 Mobyelette AV88Re: P D P D 10/08/19 09:41AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/08/19 10:55AM
  Re: New to me, 63 Mobyelette AV88Re: P D P D 10/08/19 11:14AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/08/19 11:56AM
  Re: New to me, 63 Mobyelette AV88Re: P D P D 10/08/19 01:56PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/08/19 04:45PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/07/19 08:08AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/07/19 11:17AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/07/19 12:15PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/07/19 05:10PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/09/19 09:10AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/15/19 05:46PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/15/19 07:45PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/16/19 05:45AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/16/19 08:54AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/21/19 02:40PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/21/19 07:59PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 10/22/19 08:12AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 10/22/19 09:33AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 11/17/19 05:19PM
  Re: New to me, 63 Mobyelette AV88Re: Kenneth Hill Kenneth Hill 12/17/19 08:42AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 12/22/19 04:45PM
  Re: New to me, 63 Mobyelette AV88Re: P D P D 12/22/19 06:05PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 01/06/20 11:04PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 11/02/19 07:13PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 11/04/19 10:32AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 11/16/19 02:21PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 11/16/19 04:04PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 11/16/19 04:51PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 11/16/19 04:58PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 11/17/19 09:56AM
  Re: New to me, 63 Mobyelette AV88Re: pat splat pat splat 01/06/20 11:35PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 01/07/20 08:13AM
  Re: New to me, 63 Mobyelette AV88Re: Kenneth Hill Kenneth Hill 01/07/20 10:42PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 01/08/20 09:44AM
  Re: New to me, 63 Mobyelette AV88Re: Kenneth Hill Kenneth Hill 01/08/20 02:06PM
  Re: New to me, 63 Mobyelette AV88Re: P D P D 01/08/20 03:08PM
  Re: New to me, 63 Mobyelette AV88Re: Kenneth Hill Kenneth Hill 01/08/20 11:20PM
  Re: New to me, 63 Mobyelette AV88Re: P D P D 01/09/20 09:01AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 01/29/20 02:53PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 02/02/20 09:25AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 03/09/20 10:27AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 03/09/20 11:00AM
  Re: New to me, 63 Mobyelette AV88Re: P D P D 03/09/20 11:13AM
  Re: New to me, 63 Mobyelette AV88Re: Kenneth Hill Kenneth Hill 03/10/20 08:38AM
  Re: New to me, 63 Mobyelette AV88Re: Brian Terrell Brian Terrell 03/10/20 09:10AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 03/10/20 09:18AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 03/14/20 10:35AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 03/14/20 11:12AM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 03/14/20 11:55AM
  Re: New to me, 63 Mobyelette AV88Re: P D P D 03/14/20 12:08PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 03/14/20 03:37PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 03/14/20 04:19PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 03/15/20 06:14PM
  Re: New to me, 63 Mobyelette AV88Re: Kenneth Hill Kenneth Hill 03/14/20 11:33PM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 03/15/20 06:02PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 04/28/20 10:56AM
  Re: New to me, 63 Mobyelette AV88Re: Rebel Moby Rebel Moby 04/28/20 12:21PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 12/15/20 01:24PM
  Re: New to me, 63 Mobyelette AV88Re: Dirty30 Dillon Dirty30 Dillon 12/15/20 01:34PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 12/15/20 02:21PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 12/16/20 01:45PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 12/18/20 02:29PM
  Re: New to me, 63 Mobyelette AV88Re: Ian T Ian T 04/28/20 03:35PM
  Re: New to me, 63 Mobyelette AV88Re: John Ebert John Ebert 04/28/20 04:19PM
